      Oct 2005
      New Washington, IN
      Low compression 327 pistons?
      ANyone know of a company that sells low compression, dished forged pistons for a 327 small block chevy?
      What are you shooting for in terms of compression?
      I can probably come up with something for you.
      Bret
      Bauer Racing Engines
      Specializing in late model GM motors
      1964 GTO (work in progress for 13 years)
      600 HP 365 cube SBC
      C5 Front Suspension
      Satchel Link Rear
      T56
      Not gettin done anytime soon
      2000 Camaro SS SCCA FS Car
      Koni Adjustables
      35mm Front Bar
      DOT Race tires....
      Oct 2005
      New Washington, IN
      8:1, with a 64cc head.
      Are you running a blower?
      9:1 would be fine with a blower.
      The easiest thing to do is run a 6.125" rod and any 1.250" Compression Height piston (350 with a 6" rod) in your setup and you can get whatever you need.
      Diamond has a -12cc piston that would get you 9:1 on a zero deck.
      Mahle has a -20cc piston that puts you at 8.3:1, but that's really too low IMHO.
      Bret
      600 HP 365 cube SBC
      C5 Front Suspension
      Satchel Link Rear
      T56
      Koni Adjustables
      35mm Front Bar
      DOT Race tires....
