      Oct 2015
      Western Mass
      Can I use this POSI unit?
      Have a chance to pick up a used GM POSI unit for a good price. Obviously would rebuild it, but its a 8.5" 30-spline and I know we should avoid the GOV-LOK models... so is this one of them? Don't mind extra cost of 30-spline axles. Going in a '72 Nova 8.5" 10-bolt, and if its useable, any limits on gears? I'm wanting 3.42 ring and pinion for a 4-speed BBC.
Size:  34.6 KBName:  POSI-00.jpg
Size:  41.3 KBName:  POSI-02.jpg
Size:  48.8 KBName:  POSI-01.jpg
      '69 LeMans Blue Coupe, White Interior, Massaged .030" over 454, Super T10 4-Speed,
      Holley 4150, Pertronix Ignition, CompCams Xtreme Energy XS274S, 781 Oval Port Heads
      That doesn't look like a GM LSD. It might be an Auburn, which are not rebuildable. Maybe someone else will know.
      Jun 2010
      Deployed
      There are just some things that you’re just better off buying new. I wouldn’t buy any rearend components used unless I had to....it’s so labor intensive to swap out bad parts.
      Why not one of these?
      https://www.amazon.com/Yukon-Gear-YD...90342602&psc=1
      1970 Camaro/DSE build
      Oct 2015
      Western Mass
      Yeah... the seller claimed it was a GM POSI unit and wanted $100 for it bc it wasn't for a 12 bolt. But I was suspicious so I posted the pix. I've been looking at Quick Performance for a package deal (POSI, Bearings, Axles, Ring & Pinion).
      Jun 2006
      Katy,TX
      Looks like an Auburn to me. As was said not rebuildable. Eaton or Yukon are better.
      1965 GTO project car
      2004 Pulse Red GTO
