      Jul 2020
      LS7 dry sump pan wanted
      I'm looking for a LS7 dry sump pan that is more shallow than stock. ATC, ATS, Speedtech, etc
      Sep 2017
      Hey ChevelleZ06
      ARE does have a shallow dry sump pan that uses the stock LS7 pressure pump and you add a scavenge pump to run it.
      I've been looking for the same pan you are the ATS. I bought my engine because speedtech website shows it available. I got there front subframe and rear torque arm and planned buying the ATS pan from them. But bought the engine, called to order and. Got informed no longer made.
      Isn't that nuts.
      I guess I'm going ARE
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
      Jul 2020
      Yeah, we're in the same spot. The ARE pan appears to be 0.5" less deep than stock. Ron Sutton Race Tech, 844.722.3832, said he would help find a system that works.
      Sep 2017
      They got one that's like less than 2" all the way across. But then the also have the one that looks like a stock upgrade. I'll give rn a call though.
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
      Check my new add under parts......Not sure how to share
      Sep 2017
      ChevelleZ06 did you get a dry sump set?
      I just converted to Mast Motorsports stroker oil pan kit
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
