      May 2008
      Baton Rouge, LA
      First Gen Camaro ATS/Speedtech Spindles
      Item Location (City/State):Baton Rouge, LA
      Price: 750
      Description: I have a set of Speedtech/ATS spindles that are essentially brand new. They were mocked up on my car and unfortunately my wheel/brake combination clashed and I had to revert to using stock spindles. The discoloration you see on the hub face is actually how they looked when I receive them from Speedtech.
      These are stamped ATS and have 92030004 stamped on them as well. I was asked by someone else if these are the tall or short version. I am 99% sure they are the short version. When I swapped over to stock spindles, the stock spindles raised my car by about an inch versus the ATS. I was able to get the ride height I wanted, which is very low with even the stock spindles, so these should get you where you want to be as well.
      I will work with buyer on shipping but due to weight and size I cant cover it based on the above price. Depending on where it goes I will work with whomever buys them.
      Mountain Springs, Texas
      Tall versus short refers to the distance between the two ball joint mounts, not the suspension drop. Two different things.
      Most use the tall version unless they have the Guldstrand mod.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      May 2008
      Baton Rouge, LA
      So I pulled measurements and the overall height is 7 inches. Based on my research these are the "stock" or "short" version and are not the tall version.
      Newbury Park, CA
      PM sent.
      May 2008
      Baton Rouge, LA
      Sold!
