      Feb 2007
      Tinley Park, IL
      Difficulty Greasing SPC UCA Bushings
      I recently developed a terrible bushing squeak. I was able to grease the LCA and all other steering/suspension zirks as well, except the SPC UCA zirks. My grease gun simply won't flow any grease and the handle is difficult to squeeze. I removed a zirk fitting from one of the UCA and inserted it into the grease gun, and it flowed just fine. Reinstalled the zirk fitting into the UCA cross shaft, and once again hard to squeeze the handle and no grease flowed.
      I've emailed SPC about it, but was wondering if anybody else has experienced this?
      Something else I noticed while investigating the squeak... if I loosen the nuts on the LCA bolts, the car is much easier to bounce by hand. Even after greasing the LCA bushings and snugging the nuts (not overly tight), the suspension becomes much stiffer when trying to bounce the car by hand. Like the bushing is being pinched by the frame mount. Shouldn't the metal bushing sleeve be long enough to prevent the poly bushing from getting pinched like that?
      Thank you!
      Nick ~
      1969 Cutlass
