    Thread: Help - UMI
      Nov 2007
      Help - UMI
      help/advice please... I put the wheels on for the first time today and noticed that the lower control arm is like a 1/16'' away from the brake rotor (willwood) ... Anyone else run into this issue or have an idea if this is okay, seems like when the suspension travels it will make contact with the rotor.
      Called UMI and left a message
      any ideas?
      Mountain Springs, Texas
      Is that at ride height with correct camber?
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Nov 2007
      no, suspension has yet to be aligned but pretty close to ride height
      I am not positive but adding some shims to get negative camber should gain some clearance. Do you have any shims installed?
      Nov 2007
      No shims yet
      Dec 2014
      Could clearance lower control arm or shim behind wheel bearing a little. It does not take much clearance there to be okay.
