    Results 1 to 20 of 22
      stevensville mi
      Question for all.
      I need some help
      I recently took my car back to the painter to get some misc runs and some assembly nics corrected. They ended up re-clearing the whole car and they said they wet sanded. I went to see the progress and now the car has all of these microfine scratches on it.
      1) Did he wet sand to deep?
      2) Will I be able to get these scratches out?
      3) Should I shoot him for having to take it back in the first place.
      Any help would be greatly appreciated.
      Nov 2001
      Sacramento Ca
      are the sand scratches in the clear? or in the color coat under it?
      can you feel them? If you can feel them, they will come out.
      Tony Langlois
      1966 Corvair Monza
      Nov 2004
      NW Arkansas
      we re-clear our cars 2 and sometimes 3 times brfore they are right! take some 2000 wet do a small spot then polish it out see how it looks they may not have spent enough time polishing
      KENNY DAVIS HOTRODS
      Rural Retreat,VA
      Sounds like you have a good day of wet sanding and buffing ahead of you---
      good luck
      stevensville mi
      They were so fine and I was so ticked that I do not remember if I felt them or not. The only time you saw them is when the light was hitting it directly.
      I took some hand glaze that he had there and tested a spot. I saw a little difference but the scratches were there. God I hope it is not in the base. This has been a nightmere....
      Nov 2001
      Sacramento Ca
      well since you've seen a difference then I'd have to say that most likely its in the clear, and could be buffed out. just be careful. You could burn right through, chasing scratches in the base. Something that happens all the time. what color are we dealing with? deep red or something? Is there a black additive in the base?
      Tony Langlois
      1966 Corvair Monza
      stevensville mi
      Color
      It is PPG boyd red. I just want it to be right. It is not like I am paying these guys peanuts.....
      Nov 2004
      NW Arkansas
      I'm with Tony....I say it's in the clear just needs a little more buffing.
      KENNY DAVIS HOTRODS
      Nov 2004
      Eastern Washington
      Quote Originally Posted by Travis B
      I was not aware that you could re-clear a car after it has cured. Is there a time frame that you have to get it done by?
      Nov 2004
      NW Arkansas
      Quote Originally Posted by Kuhlryde
      the red nomad we did this year was sprayed...pulled out waited 24hrs wet sanded with 600.....pushed back in and recleared.....just recently we wet sanded the roof once again with 800 and fixed two spots and recleared it again
      as long as the surface is scuffed of sanded, clear away.....
      KENNY DAVIS HOTRODS
      Nov 2004
      Eastern Washington
      Well cool. I thought you had to cut the clear and reblend it in with what you dont cut, building it backup up. I am not a painter (as you can tell), but I like learning how it is done.
      Nov 2004
      NW Arkansas
      you can burn clear in (fresh clear into unsanded clear) also but that is a whole other deal....they sure turn out nice when they have been cleared,cut,and recleared.....
      KENNY DAVIS HOTRODS
      Nov 2004
      Eastern Washington
      How much to you cut before reclearing? just before you hit color or just enough to remove any imperfections.
      stevensville mi
      My car
      They actually took off the original clear. The last time I was in it was a really dull red. They did not go directly over the top of the original clear.
      nw arkansas
      Quote Originally Posted by redsand
      when you sand clear it turns dull , then you buff back the shine . color is applied just to give it color ,you dont use color to hide or build up .
      stevensville mi
      Thanks for all of the help
      You have eased my mind a little bit. It just sucks that I took it in and it was a little fisheyed and had some runs and now the fisheye is gone but the scratches are there. Wish me luck. He is not going to get a dime until it is right. So I am thinking 2008, I will have it back!!
      florida
      you say you went to see the "progress made" if he didnt present it as a finished product then have some patience and wait till he says its "done" its perfectly normal to see fine scratches in a car that hasnt been completley buffed out yet and if he hasnt gotten to that step yet then chill out have a beer and smile man. if it shows up with scratches after he says its finished then absolutley shoot him. j/k
      Tough guys may wear pink, but Bad Asses still wear black.
      Nov 2004
      Eastern Washington
      You could always take pics. When I used to take cars to those places, I would show up with a camera throughout the job, wanting pics of the project in process. That way you could post them here.
      stevensville mi
      I showed up today and he felt that it was done and that he could put on the hauler and shipped to my house tommorrow, that is when I pointed out all of the scratches and he mentioned that they will do another glaze. You have to understand that the car was there the first time for about 6 months (He said 1 month)and now it has been there another 3 months(Said 2 weeks). Honestly I am not a perfectionist, I just want it to look decent.
      I do need a beer.
      mo
      i have never been able to get one one totally scratch free,also the the first you wash it leaves real fine scratch that will usaully come out with a real fine hand polish.i dont think you are being unreasonable.just acouple thinks to think about.
