Thread: help steel crank
Starting The Transformation
- Aug 2004
- california
- 139
help steel crank
does gm make a steel crankshaft with a 4.250 stroke with a gm stamp on the crankshaft for the big block chevy? if so does anyone have a part number?// need 5this info asap please thank you
09-23-2004 #2
- Aug 2004
- 33
In the new 8100 truck big blocks they use a 4.25" crank. That would probably have GM stamped on it, but that would also be a one piece rear main seal, and I am guessing your working with an older block given your call name of copo69. So that probably wouldn't work for your purposes.
