      May 2020
      67 Camaro Frame Rail Question
      I searched the forum, but couldn't find What I was looking for.
      Over the weekend I picked up a 67 Camaro, most of the sheetmetal has been rplaced including the floor and the trunk. In the process it looks like the rear frame rails were removed along with any of the leaf spring mounts.
      The trunk does have new shock mounts in the pan if that helps.
      I am looking for the best way to figure out where/the best process for fitting new frame rails and getting them properly located. The car did come with new front leaf spring mounts that need to be installed, but I need to get new rails. I was thinking AMD.
      any thoughts or suggestions would be greatly appreciated.
      Dec 2010
      Fredericksburg, VA.
      Art Morrison sells both front and rear subframe kits for the first gen Camaro. Once installed they can be tied together to make a complete frame.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      May 2020
      That's not a bad idea. Does anyone else make a weld in rear subframe set up?
