Quote Originally Posted by SStrokerAce
$1200 crank
$4500 block
$400 rods
$800 pistons
$3000 heads (easily that)
$1500 for Ti valves
$1000 shaft mounts
$1500 for intake setup (actually more since this is a converted 18° intake, since there are no 15° cast intakes out there.)
$2000 for the assembly and machine work
That's $16k without doing the knick nacks and the dyno time. Figure it's $20k at the least. Most likely more with the detail of the motor.
You can do 600hp on a stock block with good macine work and 23° castings, hell i've seen over 800hp from 23° stuff.
Bret
That's about what I was figuring Bret, plus the EFI system which would be intake, rails, injectors, throttle body, ECU, and wiring harness.
Jody
