      Feb 2014
      SoCal
      Ridetech Front alignment spec
      Have the front upper and lower ridetech control arms with coilovers. What alignment specs for a street driven car? Thx
      1967 GTO.
      IL/TN
      there is no given set up, it depends on what you want to do or expect but since you are on this forum I would start with 3/4-1* negative camber, 4-6 * positive caster and 1/16 total toe in, but you need to adjust to fit your application.
      https://www.protouringf-body.com "doing what they say can't be done"
      Feb 2013
      The specs he listed above are right at what we recommend. From those base dimensions, it's really preference from that point.
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Lawrenceburg, TN
      street... ¼ to ½ neg. camber, 3 to 4 pos. caster, 0" to 1/8" Toe In
      Lawrenceburg, TN
      RACING 1 ½ to 2 neg. camber, 5 to 8 pos.caster, 1/8" out to 1/8" IN......toe out on a short autocross track with tight turns, toe in on road course
