      Nov 2016
      Cape May County NJ
      Need some help selecting headers
      I am swapping in a LS motor into my 1970 Camaro (408ci LQ4).
      I need some advise on headers.
      I have read a lot of threads but I am still a bit confused.
      I think I need to go with 1-3/4" primarys.
      My big concern is ground clearance. Some seem to hang really low.
      So I guess my question is what headers are you using and how is the fit?
      Craig
      A mans garage is his castle.
      Jan 2020
      Northern VA
      Stock sub-frame or aftermarket? A lot of people that run the Detroit Speed sub frame use their headers, which are super expensive but, from pictures i've seen they fit very tight to the body. I believe hooker makes a set too and they're a little cheaper.
      Nov 2016
      Cape May County NJ
      Stock sub frame. I have heard that you must use the Holley motor mounts to use their headers.
      Apr 2012
      Woodstock, IL
      Quote Originally Posted by SS Performance View Post
      Ultimate Headers will fit. 1 7/8 would be better for a stroker which is that they’re sized at.
      -Dale
      SchwartzPerformance
