      Oct 2009
      Tensioner position
      When measuring for a drive belt what position should the tensioner be in when the belt is installed?
      Right now my tensioner is pulled 3/4 of the way to the stop
      Just wondering if thats enough play
      Thank you
      1969 frost green camaro
      LS3
      Speedtech pro touring front subframe
      ridetech rear 4-link
      moser 12 bolt eaton tru trac 3.73
      Newbury Park, CA
      That should be fine. Typically 2/3 from rest is the target.
      Jan 2014
      Portsmouth NH
      I agree with Carl on this for a conventional belt. However if you are going to use a Gates RPM or similar the belt tensioner only needs to go 1/3 to 1/2. This is because these type of belts do not stretch as much.
