Thread: Comp Cams XR274R?
12-21-2005 #1
Comp Cams XR274R?
Is the comp cam XR274R a good weekend driver cam?
I`m thinking about using it in my 383 stroker Chevy:Edelbrock rpm 64cc heads. 9.98 compression that sits in a Chevelle -65 with 1900-2600stall th350automatic, 3.36 ratio rear axle.
Can it be a good combo?
All under 6.27 litres is a starter.
12-21-2005 #2
Starting The Transformation
- Nov 2005
- 130
I'd probably put more compression and more stall at it.
You would be better off with the XR268R and 1.6 rockers with the parts you have.
BretBauer Racing Engines
Specializing in late model GM motors
1964 GTO (work in progress for 13 years)
600 HP 365 cube SBC
C5 Front Suspension
Satchel Link Rear
T56
Not gettin done anytime soon
2000 Camaro SS SCCA FS Car
Koni Adjustables
35mm Front Bar
DOT Race tires....
