04-20-2020 #1
- Oct 2011
- 721
How Are You Mounting Aluminum Radiators?
Hey guys I have en entropy radiator for my 69 Camaro, it didn’t come with any instructions, so I was just wondering how are you guys mounting your aluminum radiators to the core support? After seeing Stielow’s car that he’s working on on Lat G, I was thinking to use rubber grommets in the radiator then put a hollow spacer inside the grommet then mount with a bolt (hope my explanation makes sense). This way the radiator isn’t hard mounted to the core support. Aluminum expands and contracts way more and at different temperatures than steel perhaps this would be a way to prevent cracking. Just curious if my actual idea would work. Grommet followed by spacer (same thickness as grommet) then bolt inside the spacer.
thanksMy Very Ambitious 69 Build
https://www.pro-touring.com/threads/...lls?highlight=
