    Results 1 to 11 of 11
      Feb 2007
      The Netherlands
      Country Flag: Netherlands
      Wheel hopping, how come?
      I have a 69 Nova with ridetech 4 link and shockwaves. I have 325 tires in the back and if I want to do a burn out my wheels start hopping ;-(
      How is this possible and what can I do to prevent it?
      Please advice
      Thanks, Bram
Size:  285.7 KBName:  20190622_164703.jpg
Size:  204.7 KBName:  20190622_164648.jpg
      Apr 2010
      Jersey Shore
      Have you tried adjusting the shocks all the way in either direction?
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
      AutoWorks Middletown, NJ
      Feb 2007
      The Netherlands
      Not yet, I'll try next time I take her out.
      Feb 2008
      Macomb County, Michigan
      Is the Nova at ride height? If it is, how do you turn the front wheels without hitting the fenders? I'm just curious, I also have a Nova.
      This is getting very expensive?
      Feb 2007
      The Netherlands
      Quote Originally Posted by 409novaman View Post
      haha, no this is when its totally down (airride) I can't move the car at all in this position. It has to go up for about 3 inches to drive it.
      Dec 2010
      Fredericksburg, VA.
      How are your lower bars angled? My lower bars are slightly angled down front to rear which has the effect of the rear axle trying to drive the body up and the axle down as the car moves forward. I would also recommend adding more rebound in your shocks. The problem I had was wheel hop under hard braking which required an adjustment to the proportioning valve to reduce rear brake.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      IL/TN
      how is it possible? because wheel hop is not just a problem with leaf springs as many believe, many things can contribute to it, pinion angle, instant center, geometry, traction, springs and shocks.
      https://www.protouringf-body.com "doing what they say can't be done"
      Ontario, Canada
      This won't help your car, but I eliminated wheel hop in my Nova by raising the front leaf spring eye by 1 1/8". I replaced my Nova spring mount bracket with a '69 Camaro bracket.
      If the changes in shock settings don't help try changing the angle of the lower control arms.
      Ken
      My other car is a Vega.
      IL/TN
      Quote Originally Posted by Kenova View Post
      Ken
      this makes no sense, the nova brackets are the same as the camaro
      Feb 2013
      A lot of the posts above are information that I'd be curious to see as well.
      Does your rear lower four link bar have adjustable mounting holes?
      What kind of angle are the bars at while you're at driving height?
      What is the pinion angle?
      Which Shockwaves do you have on the car? and where is the adjustment knob set at?
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Ontario, Canada
      Quote Originally Posted by 79T/Aman View Post
      I believe '67 and '68 Camaro brackets are the same as the Nova, but the '69 Camaro bracket places the spring eye bolt 1 1/8" higher. There is also some slight misalignment of the bolt holes that are used to bolt the bracket to the body but that can be taken care of with a round file.
      Ken
