      Plantation, FL
      Help Identifying Rear end
      Can anyone identify this rear end?
      It is a 12 bolt that I just took it out of my 1969 Camaro. It appears to be a posi and has a 4.11 gear ratio and the mounting flange holes match the std 12 bolt chevy pattern. I am changing brakes and am trying to figure out which WIlwood rear brakes set to order and I can't figure out what type of rear end this is.
      Steve
      69 Camaro
      May 2010
      kitchener,Ontario,Canada
      A body . I dont gm had run any other cars with triangulated 4 link and a 12 bolt ... maybe a B body . You need to take some measurements mounting flange to mounting flange
      Ryan Austin
      On Instagram ryanaustinss70
      Plantation, FL
      Thanks. This may point me in the right direction. Measurements flange to flange in 54 1/2". Total width of axle to end of tubes is 57". I'll check out the measures of B body axles.
      Steve
      69 Camaro
      Plantation, FL
      I also measured the wheel mount to wheel mount and that is 60"
      Steve
      69 Camaro
    Tags for this Thread
