Results 21 to 27 of 27
Thread: Six Speed Dreams
12-18-2005 #21
- Aug 2004
- Encinitas, CA
- 219
Stock floor is fine - you carpet will cover the floor mods and you will probably not even notice that anything has been done underneath. You You can use the stock Tremec shifter that is included with the TKO when you buy it. The console cars require an optional offset shifter.
Jeff Mortenson
12-19-2005 #22
Banned
- Aug 2003
- Orlando, FL
- 8,745
Andrew, for gears I would look in the 3.42 to 3.55 range. TKOs have a much lower first gear, so it will feel like a deeper rear gear then a 4 speed at launch. And with the overdrive the 3.55 will feel much taller then your present 4 speed at cruise.
12-19-2005 #23Andrew, unless you have a console you won't need to add the shifter hump. Unlike the T10/Muncies/Saggies which have the shifter linkage on the driver's side of the tranny, the TKO shifter mech. is top-mounted (i.e. the linkage is internal). Take a look at this page on Jeff's site, these are pics of my install.
Originally Posted by 69Nova
http://www.classicchevy5speed.com/68...tall_notes.htm
Dan
12-19-2005 #24
12-19-2005 #25
- May 2005
- St. Augustine, FL
- 1,529
Thats good to know. I want it to look just like how you did yours.Andrew, unless you have a console you won't need to add the shifter hump. Unlike the T10/Muncies/Saggies which have the shifter linkage on the driver's side of the tranny, the TKO shifter mech. is top-mounted (i.e. the linkage is internal). Take a look at this page on Jeff's site, these are pics of my install.
ThanksAndrew Petty
12-19-2005 #26If you want to make some good money on your transmissions sell them on e-bay. I couldnt believe how much my old 4 speed BW T-10 sold for on there and it was completely destroyed. I even sold the clutch pack and flywheel on there to get all new stuff.
Good luck on the TKO or T56 swap. I am very happy with my T56 but I only have around 400hp. Either way you will be a lot happier with 5 or 6 gears compared to 4.
Makes a huge difference in gas mileage.
12-19-2005 #27
- May 2005
- St. Augustine, FL
- 1,529
Yea I'm going to try ebay. My dad's friend sell stuff all the time so I going to ask him to help.
Andrew Petty
