    Results 1 to 10 of 10
      Nov 2014
      T56 Magnum trouble
      Ok, here is a good one. The T56 Magnum in our 1st gen with NA LS3 pushed the rear seal out at the drag strip. No biggie. We pull frame stiffener, driveshaft, and replace the seal. Nothing appears to be abnormal. Put the car on the ground and it pushes the seal out again 2 blocks from the shop.
      This car has been together for years, LOTS of miles logged without issue. Tranny and clutch seem fine and I grabbed the vent tube and it did not appear tight or pinched. Also the vent cap sounds to be free and rattles.
      Before we yank this thing (yuck) I want to see if others have had issues similar to this. Thanks, Matt
      Jun 2010
      Deployed
      Quote Originally Posted by btmatt View Post
      Yup, I have heard this before. I pulled my all
      rubber seal and installed a ford seal that has a metal body. I’ll have to see if I can dig up the part number. I was given the info from another member who had seals blow out.
      1970 Camaro/DSE build
      Jun 2010
      Deployed
      Nov 2014
      Just saw this. Maybe I should try and search next time. Ha
      I did remember that when I bought the yoke it will fit a C6 trans. On a hunch we went to the local autozone and bought a seal for 66-76 F150. Checked the dimensions and it was a match. As noted the seal is not rubber clad like the original. We installed today and so far so good.
      I will update later. Thanks
      Feb 2016
      Lawrenceville, IL
      If you get the chance to check for this, look at the tailhousing before you put the new rear seal in. There should be two oil passages between the slip yoke bushing and the body of the tailhousing (see pic). Those are drainback holes to allow fluid that gets trapped to return into the main case. Tremec had a batch of these Magnum tailhousings that didn't have those oil passages machined into them. This allowed fluid to build up and eventually force the rear main seal out. If your's doesn't have these passages, you'll likely see this issue creep up again. Unfortunately the only real fix is to replace the tailhousing, but Tremec has been good about taking care of these for customers.
      Name:  T-56 Magnum Drain Back Relief areas.jpg
      visit us on the web at www.bowlertransmissions.com
      Nov 2014
      Thanks for the reply, Craig. I had read about the drain holes, but had not seen a pic with the detail you show.
      We have installed the new seal and no issues so far. If it begins to weep I'll pull the seal and check for the drains. Thanks, Matt
      Apr 2012
      Woodstock, IL
      We had the issue Craig stated and TREMEC sent us a new tail under warranty.
      However it took too long (only a week) and the car was taking up space on the lift so we machined the tail with an end mill and never had an issue again.
      -Dale
      SchwartzPerformance
      Dec 2008
      Detroit
      I had this same problem. Wish I had known about the drainback holes before a installed a new seal....I'll definitely check next time.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Jun 2010
      Deployed
      Interesting....I didn't know the tail housing may not have been machined. I know the metal housing seal I did install has a weep hole...I guess time will tell.
      Oct 2007
      SO I am a lucky one... I starting putting some miles on the camaro, trans leaks all over the floorpan. Thanks to this thread I was easily able to find this problem
      Thank you Bowler Transmission !
      Quote Originally Posted by Craig@Bowler View Post
      67 Camaro In progress
