    Results 1 to 15 of 15
      May 2009
      Where/How to make custom A/C Hard Lines?
      With the serpentine swap complete, it has placed the compressor on the opposite side of the car. Also the condenser fittings are on the opposite side.
      I am going to try and get a new condenser with reversed fittings, along with a few other items.
      Custom hard pipes would really clean things up in the engine bay.
      Any thoughts or recommendations?
      Mar 2015
      I save any extra hardline stuff I come across so I can cut and weld to make up what I need. Not sure where to get a flare tool that does the ends. I'd like to know myself.
      It is possible to use flare fittings for hardlines and hoses. Flares were used for years until GM went to a Tube-O fitting common thru most of the 90's. Recessed O-Rings were used in the early 90's to mitigate leaks caused by O-Ring nicks on installation, the lead-in pilot used to better align the O-Ring. The double O-Ring fittings in common use today is a further refinement to reduce leaks.
      Quote Originally Posted by showdog75 View Post
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Nov 2015
      South Jersey
      I had to relocate my AC dyer and used the aluminum U-Bend Em lines for Vintage Air. They are pre-made lines with the ends installed available in 12" increments up to 72". You can bend them with a standard tubing bender to make a custom fit. This was one I made up from a 12" U-Bend Em line. I painted it black to hide it behind the grille.
      69 Cougar
      Schwartz Chassis
      5.0 Coyote
      T-56 Magnum 6 Speed
      Baer Brakes
      May 2009
      Quote Originally Posted by lxg44 View Post
      Thanks a lot
      That's awesome!!
      Feb 2019
      I see you are using a Vintage Air dryer. Can you tell me which one you are using as the only horizontal ones I see are polished or black anodized ones. I would also like to mount a trinary switch on it as you did. It looks like yours has fittings at both ends.
      Mar 2015
      Having to cut and weld my #6 hard line coming from the condenser to the dryer.
      Nov 2015
      South Jersey
      Quote Originally Posted by Perry M View Post
      This is the replacement dryer I bought from Summit.
      https://www.summitracing.com/parts/v...-vuc?rrec=true
      This is the same dryer but includes the trinary switch.
      69 Cougar
      Schwartz Chassis
      5.0 Coyote
      T-56 Magnum 6 Speed
      Baer Brakes
      Mar 2015
      I may be wrong but I don't think his dryer is horizontal instead the picture is turned 90°.
      Feb 2019
      OMG, you are right. I sure missed that one. Thanks
      Nov 2015
      South Jersey
      That was a good catch! Its funny, on my phone the pictures are oriented correctly so I looked right past the horizontal part.
      69 Cougar
      Schwartz Chassis
      5.0 Coyote
      T-56 Magnum 6 Speed
      Baer Brakes
      Apr 2008
      I have to ask, what technique are you using for the welds on the HVAC lines? Is this just standard TIG, silver hard solder/braze (doesn't look like it) or something else? Thanks for any info.
      Mar 2015
      Quote Originally Posted by Hey_Allen View Post
      Good ol tig
      Apr 2008
      Good ol tig
      Thanks.
      Definitely need to work on my TIG skills, two projects already pending that need it, and this makes three!
      Oct 2015
      Western Mass
      Man... you've got some advanced TIG welding skills. I switched from a driver's side V-belt compressor to a serpentine that puts the compressor on the passenger side, so I ordered new hard lines from VA.
      '69 LeMans Blue Coupe, White Interior, Massaged .030" over 454, Super T10 4-Speed,
      Holley 4150, Pertronix Ignition, CompCams Xtreme Energy XS274S, 781 Oval Port Heads
