      Sep 2013
      Touch up on Candy Colors
      Anyone have this done and completely satisfied with results. I need a couple of spots looked at but really concerned with what will look like when work is complete. In Louisiana so would like to stay close by also. Any names to check with would be appreciated. Thanks.
      1967 Nova LS3 w/ 4l80 all TCI suspension with Ridetech coilovers, Detroit Speed mini tubbed with 18" Billet Specialties Prism wheels and 315 tire in rear, Wilwood Brakes, Quick Performance 9", custom interior, Fesler flush mount glass, Black Widow exhaust, vintage air and Kenwood bluetooth sound.
      Aug 2008
      jacksonville,fl
      Do you at least know what paint manufacturer & color codes were used? would be a helpful start. Also , are we talking minor scratches & chips, or more major?
      Sep 2013
      Quote Originally Posted by jlcustomz View Post
      Yes I have paint code and all. Little more major.
      May 2018
      way east on a rock
      As much as I love the candies and 3 stage paints, I'm going 2 stage this time around because it's insanely hard to get a blend/match on touch ups. Plan on painting the entire panel and the original code you went with not matching. If you have a really patient paint man, they will tweak it to perfection, just takes a few tries. Just my .02 from my own experiences with candies and 3 stage.
      Aug 2008
      jacksonville,fl
      In that case, entire panel will probably be reprimed & started over, hopefully they can work up to your stripes if needed. Then reclear panel. Perfect color & flip flop in various lighting match is never easy, but at least the color you have is far easier than a silver. Grew up in southeast La, but doubt anyone good I knew growing up is still painting or breathing.
      Small spots may be able to be airbrushed & blended into panel, but likely never near perfect up close. A good panel repaint with the paint codes & mix job hopefully being close enough is usually what gets done & has a strong chance of being plenty close enough with the right painter.
      Mountain Springs, Texas
      Is it a tricoat or a true candy? If it’s a tricoat any quality body shop should be able to handle the repair. True candy is a whole different game.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
