      Sep 2013
      Country Flag: Finland
      1967 front shocks
      Is anyone using this kit? https://www.ebay.com/itm/Chevy-67-69...3a7a%7Ciid%3A1
      Its quite affordable and maybe ordering The Set to test those shocks and springs.
      May 2014
      Stanislaus County Ca.
      I good deal on a coil over CONVERSION may not be better or even close to a good conventional spring and shock setup. Like spring and shock from Hotchkis,ridetech,etc...
      IL/TN
      if the picture is the actual product the coil springs will probably coil bind not to mention that you won't be able to install them as the shock is too short and that bottom bushing (despite being red);-) will fail
      https://www.protouringf-body.com "doing what they say can't be done"
      Arizona
      Don't Do It!
      You get what you pay for,,,,, If you go that way you will be changing them again soon.
      Dec 2010
      Fredericksburg, VA.
      Not to mention the fact that the lower end of the shock would likely break out the shock mounts on the LCA since the entire weight of the car is no longer on the spring pad but concentrated on the lower shock mount. REALLY BAD DESIGN!!!!
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Sep 2013
      Thanks for The replyes! Yes The design IS Bad, The whole weight goes to The two shock bolts and thats too much for those little bolts. Well gonna look for other options
      Quote Originally Posted by 79T/Aman View Post
      We can Agree on things!
