    Results 1 to 9 of 9
      Sep 2009
      Port Richey Fl
      1965 Mustang Restomod Convertible
      Reliable trucking delivered this 1965 Convertible for a customer from Va November 2018. At first this looked like a very nice Mustang with very little rust but you can tell it wasn't a good paint job. She still wants it painted "Baby Blue" and mostly stock on the outside. Her Husband is building a new small block with a C4 transmission with a Gearvenders overdrive. We will be installing DSE front and rear suspension and she wants leather interior. They bought this back in Aug. 2018 and they wanted a rust free Mustang when we are finished with it. I suggested she drive this one for the 1 1/2 years it was going to take to restore and sell it when we finished building the 65 convertible we had behind the shop. To make it rust free everything has to be removed to get to the inner structure and epoxy primed. She wanted this one restored
      Rusty Gillis
      Former SS/FA & SS/GA NHRA National Record Holder
      Aug 2014
      Quote Originally Posted by rusty428cj View Post
      Is that like 1"+ of bondo? Ouch!
      Sep 2013
      sw Kansas
      Just up your alley.
      Sep 2009
      Port Richey Fl
      Back from the sandblasters. Brian has a lot of rust repair before the fun starts installing the DSE suspension and flaring the fenders and quarter panels.
      Rusty Gillis
      Sep 2009
      Port Richey Fl
      I sprayed two coats of SPI epoxy primer on the area that won't be replaced.
      Rusty Gillis
      Sep 2009
      Port Richey Fl
      The upper cowl was stripped to bare metal and epoxy primed
      Brian is getting ready to cut out the rust in the lower cowl
      The rust was cut out and a patch panel was welded in place. When you install aftermarket AC the cowl vents are blocked
      Rusty Gillis
      Sep 2013
      sw Kansas
      Blasting is our friend and enemy. It does bring truth to the story.
      Sep 2009
      Port Richey Fl
      The lower cowl was removed.
      All the rust was removed and epoxy primed
      The back side of the dash was sanded and epoxy primed
      Lower cowl clamped in place and Brian spot welded.
      Brian welding the upper cowl and welds cleaned up.
      Rusty Gillis
      Sep 2009
      Port Richey Fl
      We decided to replace the floor since there was a lot of small holes in it.
      Found a few small holes in the inner rocker panel
      This is what we found in the inner rocker panel.
      Both left and right inner rocker panels along with the right outer rocker panel were replaced.
      Also replaced the lower right A pillar
      New floor pan sanded and epoxy primed before installing
      Rusty Gillis
