    Results 1 to 15 of 15
    Thread: Not Level
      Dec 2019
      Ellenboro, NC
      Not Level
      Why is my car sitting 1" to 1.5" lower on drivers side? Front and rear.
      Aug 2015
      charlotte
      'cause you heavyyyy
      Nov 2016
      Sulphur, La
      With all the information you provided I would say that slimjim's hypothesis is as good as anyone else's will be! Throw us a bone and tell us about you car.
      Dec 2019
      Ellenboro, NC
      Quote Originally Posted by slimjim View Post
      'cause you heavyyyy
      Ouch!
      Dec 2019
      Ellenboro, NC
      I just bought the car and was looking at some wheel options. It's got 2" lowering blocks in rear and was told 2" lowering springs in front. I was looking at wheel wells thinking about having them rolled and I noticed the passenger side was higher around an inch. The guy I bought it from was a pretty big man, but hasn't put a lot of miles on it. I just thought it odd for front and back to be low
      TuoCo, CA
      Still need details to answer that question. Start with year make and model of car and we might start making better guesses. A couple pics might help too.
      Steve
      Check it Out Here
      Feb 2019
      Kankakee IL
      Quote Originally Posted by mgb View Post
      Try swapping the springs. left for right.
      Tracey
      IL/TN
      lowering blocks?! so it's possible the leaf springs are old stock ones? bushing condition?, body bushing condition?
      Sep 2016
      Bakersfield, CA
      When I totally re-did ALL of my suspension and body stuff, my 69 Firebird would sit no perfect level side to side either.
      After about 800 miles on all of it now, and measuring it side to side ALL the time, I have found that it just depends on how the car ends up when parked. Depending on what direction I come into the garage, people getting out of it, etc. changes it. Sometimes it's perfectly level, sometimes the driver's side is lower.
      My variance has been as much as 3/4" of an inch side to side both front and rear at the most tho.
      http://www.TheFOAT.com/92GTA
      1969 Pontiac Firebird
      w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black with black interior.
      Dec 2019
      Ellenboro, NC
      67 Camaro SS. I don't know if the leaf springs are original or not. Previous owner is no help. I'm new to the 1st gen Camaro. It has AR TT2's 18x9 255/35 rear, 18x8 235/35 front. I am wanting to lower it about another 1"-1.5" and get it to sit level (left to right). All I know at this point is that in the rear it has disc brakes, new looking Edelbrock shocks, 2" lowering blocks and traction bars.I haven't checked out anything because I don't know what to check. So please get me started on the right path. I know this is a pro-touring forum, but I'm really just looking to lower the car on a tight budget.
      Elk Grove, CA
      I had that same problem on my 69 Camaro. I installed new Global West A-Arms with new could springs and noticed it sat lower. Check to see if the left could spring is sitting right on you lower A-Arm. It still sat lower on the left side after I made sure the spring was in the groove (which it wasn’t) so I finally went with Coil-Over Adjustable shocks and that fixed both the front and rear leveling problem. You don’t have to spend a bank roll on them as they come in different price ranges. You can also raise and lower your ride height to your specific needs and they look cool. 😎
      Sep 2016
      Bakersfield, CA
      I don't know about Camaros, but on a Firebird the spring clocks from the top. There are tiny holes on each side for being able to see the end of the spring is all the way into its the groove. The top perch is molded in the spape of the end of the coil spring just for this.
      TuoCo, CA
      I’d check that the coil springs are correctly in the subframe pockets.
      Steve
      Check it Out Here
      Fredericksburg, VA.
      Quote Originally Posted by Tsaints1115 View Post
      This! Also, take some pics of the suspension so we can see what you have since you apparently have no clue.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Nov 2014
      AZ
      First confirm your front and rear subframes are level with the ground left to right, that is what matters most. I see a lot of first and second gen Firebirds, maybe other GM cars too, do not have perfect symmetry in the fender panels and wheel well openings left to right, that isn’t an accurate measure of “level” only a reference to a before and after changes specific to ea corner.
      Other reference points might be the door striker, The corners of the roof water channel trim, headlights?? Don’t expect perfect precision in design/manufacturing from the ‘60’s.
