      Dec 2019
      Missouri
      Help. Header clearance issue.
      I have a 69 Firebird, with a Chevy 350 motor, It is bored out to 408 stroker. I am no mechanic or restorer. Other day they installed motor and went fine, when put headers on they did clear steering box by 1/4 inch. Problem was down low. Driver's side barely hit, had to dimple. But passengers side was bad, they had steering turned all the way to right when installed, they later noticed that when they tried to turn wheels back to left they could not. Where centerlink meets with Idler it hit pretty good. It does have 69 Firebird steering linkage. Does anybody out there have 69 Firebird with Chevy motor? I am told that if swap out all 69 Bird linkage with 69 Camaro linkage it would work. They actually are different. Or go with rack and pinion. Please help. Anybody know for sure what to do? Thanks . Jerry
      Dec 2010
      Fredericksburg, VA.
      I would look into a R&P upgrade.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Aug 2010
      Seattle area
      The Firebird and the Camaro are both "F" bodies And use the same frame . I had a friend of mine swap a big block Chevy in place of the 400 Pontiac engine of which had gone south. of which ha no issues I would go with another brand of headers such as Hooker .Doug Thorley Just tell them what you did.I wish you luck.
      Dec 2019
      Missouri
      Thanks for replies. I actually have the Hooker now (2131-1. Ceramic coated). I called Hooker and Hedman , both said they do not offer a swap header for Chevy motor into 69 firebird. Just have to go with the Chevy header. Would a rack and pinion rear steer work or would I need a front steer?
      Mountain Springs, Texas
      Rack conversions perform poorly imho. Bumpsteer and header fit issues are common.
      Try the Camaro center link. They are easy to find.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
