Results 1 to 11 of 11
10-28-2019 #1
68 Camaro Front Disc Brake Kit suggestions
Hello, read many threads but haven't found exact answers matching my need. Please ignore my amateur level, im new with classics.
Currently working on suspension setup, but want to start planning/saving for Disc brake setup.
I don't know what rotor or pads etc I have on. Built by a previous owner. After my LS2 Swap, car doesn't brake well. Very weak.
Note: Just street driven, no track/autocross.
Wheel size:
17x8, 4.5b/s, 0mm offset, 5x120.65 bolt pattern
Here's are my amateur questions:
1) Someone mentioned, just changing the fronts would be fine, yes?
2) Do you advise for a whole Front Disc kit?
3) Do you advise I replace one item from my current setup?
3) When advising, if you can please add the Item SKU number so I can look it up on summit etc.. Also, if this "item" is direct replacement/fit or needs other components/modification.
Here's a photo of my brakes.
Thank you1968 Camaro SS | LSx 364ci
T-56 | RT StreetGrip | RT Steering Kit | TRSD Disc Brakes | Wilwood Dual Piston
