      Benicia CA
      Which tall ball joint?
      Hi guys.
      This post is a side note to my post on my "baffling" suspension issue. I'm going to reinstall the stock spindles on my Ride Tech control arms as a test. I'm told I need to have a tall ball joint to prevent binding with the Ride Tech upper arm. Proforged make a .5 inch tall and a .9 inch extra tall ball joint. I currently have the tall L&H spindles which are 1 1/2 taller than stock.
      My question is which tall ball joint would work better, the .5 or .9? The .9 seems like an obvious choice as I already have been using a 1 1/2 inch taller spindle, but that also seems like a lot of leverage on the ball joint.
      I'm also going to order the tall outer tie rod ends as recommended to help reduce bumpsteer.
      I've check David Pozzi's site but I can only find info on the .5 ball joint.
      Thanks for any insight.
      Joe
      Joe G
      69 Coupe; ZZ430;TKO 600 5 speed; 3.55 posi; 13" Baer 4 wheel discs; 17" Billet Specialties wheels; Hotchkis/Koni rear; Ride Tech Strong Arms and coilovers front; Classic AutoAir AC and power windows now cuz I'm old and lazy!
