      variable blower motor speed, how to?
      I was thinking about ditching the resistorpack, because I don't want to clutter up my engine compartment with wires. But I have yet to find anyting else that would work. I was thinking about what Vintage Air is using for their speedcontrol for the fan motor. Anyone know how they do it? or have other ideas?
      Please share your thoughts
      /Dan
      Farmington Hills, MI
      As far as I know, everyone uses a combo of resistors. Some use var. res. like a potentiometer. That would be less wires. Umm, I dont know of anyone who sells a kit or anything. Even if you use the resistorpack, all your wires should be under the dash and just 2 wires to the motor, var. ground, and 12v supply.
      JEff
      JEFF SHORTT
      -IDEAL STEEL
      well the resistorpack have to be mounted so that air flows over them for cooling or they will burn out. I was woundering if there might be other more modern resistorpacks, that are not as large as the one I have now.
