      Aug 2010
      Rear brakes not getting pressure?
      I have my Wilwood proportioning valve turned all the way in to get max line pressure to my rear brakes, but I can't seem to be able to get them to lock up. Granted, I have BP30 pads in my Aerolite fronts and BP10 in the FNSL rears. I switched out the 30's I had in the rear because I was getting a weird harmonic vibration sound when rolling to a stop, or moving forward very slowly. The sound went away after the bp10's went in, I can't seem to be able to get the rears to lock up before the fronts on pavement. I know the front pads are much more aggressive, but I thought I could adjust for that with my proportioning valve. I thought the combination would give me the feel I wanted for the street without the increased wear on the rears between track days. Thoughts?
      Joe
      1969 Firebird Project
      1967 Frirebird 400 convertible
      2013 Boss 302
      Apr 2011
      Rosser Manitoba Canada
      The prop valve can't increase pressure so the first course of action would be to remove it.
      Oct 2014
      DFW, Texas
      Bleeder pressure gauges aren't very expensive, I used it to check my Wilwood setup. May be worth trying.
      1972 Plymouth 'Cuda - Not LS-swapped, 5.7L Hemi [MS3 Gold Box], T56 Magnum 6-speed - 'Cuda Build Page
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
      Oct 2011
      Is it possible that you have your MC lines reversed? I believe pressure is applied to rear brakes first then front that’s why a proportioning valve is needed.
