      Aug 2006
      Hood Hinges Recommendations
      Hi Guys
      I have stock hood hinges on my 68 camaro with steel hood. When I close the hood, the rear corner on the driver side stays up a bit, and I have to push it to bring it down.
      I have been searching around and found Billet Hinges made by Ringbrothers, Fesler, Eddie Motorsports, Billet Specialities. They all look high quality and very pricey at the same time. I do not want to spend too much money for an item, which I will up with issues at the end.
      Unfortunately, despite of being pricey, I have read some negative reviews about Billet Hinges. For example some have opening less than stock, or the hardware supplied with the hinges get stripped after several times of removing the hood.
      Besides the Billet hinges, anybody using stock hinges? I have noticed that Goodmark hinges are more expensive compared to other brands
      __________________
      72 Camaro RS:SOLD
      68 Camaro:
      LS6 Engine,Tremec TKO 600,5 Speed
      Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors
      Feb 2018
      Southern IN
      Your hinge springs need replaced, that's why you have to push the back corner(s) down when you close it. My 68 Camaro was the same way. I went with the Eddie Motorsports hinges and have been very pleased...no side-to-side movement when the hood is up and very smooth operation. It also opens at the same angle that it did with the stock hinges. Anytime you use stainless bolts you need to put anti seize on them or you'll regret it. Mine is a steel cowl hood btw. Good luck!
      Shane
      #theanchorholds
      68 Camaro build thread:
      http://lateral-g.net/forums/showthread.php?t=56387
      Aug 2006
      Quote Originally Posted by Gmachine1911 View Post
      Thanks Shane for the valuable input. Members in Lateral-g also recommended Eddie Motorsports Hinges. They are simple and nice looking as well. I am leaning towards the black anodized ones.
      72 Camaro RS:SOLD
      68 Camaro:
      If you're not set on billet
      http://www.hoodhingerepair.com/
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
