      Elk Grove, CA
      700R4 Hard Shift
      I recently converts my 69 Camaro to EFI using a Holley Sniper set up, I’m very happy with it. Since I installed it my tranny shifts hard from 1st to 2nd now, is the tv cable set to tight or to loose?
      Feb 2016
      Lawrenceville, IL
      A "hard" shift is usually a sign your cable is set too tight since it's increasing the line pressure at a quicker rate which then results in a longer, harder shift condition. The tricky part is getting it set correctly since any adjustment you make affects all the gear shifts. The 1-2 shift always seems the hardest because of the massive gear ratio change. I would at least have a transmission shop put a pressure gauge on the trans and set the cable accordingly or look into our Tru-Shift system that will correct your cable length for the Sniper system. Let me know if you have any other questions.
      visit us on the web at www.bowlertransmissions.com
      Elk Grove, CA
      That’s a great suggestion. Since I’ve posted this I looked on YouTube for help and it was helpful. I think my best bet is to have it checked by a good transmission shop. Leave it to the pros
