Thread: 1970 GTO LS Turbo
08-24-2019 #1
- Aug 2019
- 3
1970 GTO LS Turbo
Hello everyone, my name is Josh and I have a 1970 GTO to rebuild. It is complete but rough. I have torn it down to body, frame and powertrain left. It is a rust bucket. Bought another clean 70 GTO body out of Reno. After spending weeks, slowly realizing rebuilding a Pontiac motor by anyone good will cost a small fortune. I decided to go LS. I am shooting for a $15k budget. I am going to Turbocharge the LQ4 block out of a2005 H2. Its a 6.0L iron block, aluminum head truck motor. I am either going to fully build the motor or leave it stock. Shooting for 500-600 whp. 4l80E trans. Stock rearendwth 3.23s. Will post picks soon.
Ideas:
stock rebuilt 4L80E or stage2-3 but cost is a factor
summit pro LS pistons and rods stock length and bore because boost and thin walls after boring- .005 over max, -12cc dish pistons stock rod length, summit rings
18x8 front wheels, 18x10 rear, 245/40r18 front tire, 275/40r18 rear tire
.550 int/.550 exh cam from jegs
Cam Motion full valve train kit, seals, retainers, dual springs, timing kit, pushrods, etc. or just PAC 1218 springs and stock hardware, with upgraded trunnion kit
stock crank, micropolished
LS6 intake
80mm truck TB
stand alone wiring harness stripped (by me)
80 lb/hr siemens injectors Ev6
flat truck 6.0 flexplate, with spacer/adapter and bolts
corvette 58 psi fuel regulator
450 lph pump with manifold and fittings
EFI tank notched
holley 302-2 oil pan with gaskets and pickup
melling water pump
LS9 head gaskets- on 4.00-4.005 bore block
summit control arms fr/rr, springs, shocks,
s475 turbo
precision turbo 46mm wastegate and 50mm bov
arp head studs
summit stock oil pump
speedmaster fuel rails
summit intercooler
160 deg thermostat
summit sway bars and spindles stock height
CPP or Right Stuff big brake kit
HP Tuner Pro
and probably some things i forgot
Thanks. -JB
08-24-2019 #2
- Aug 2019
- 3
I came back to post pics and it I harder than I expected. I guess I am unsure of how to do this haha. I will get pics up though. Any help is appreciated. Thanks- JB
08-25-2019 #3Its a pretty good start.
A stock 4l80e rebuild with dual feed and recalibration will take you pretty far. Dont forget the converter$$$.
I dont think the vette fuel regulator will work. You need boost referenced.
08-25-2019 #4
