Thread: oil sensor?
09-22-2004 #1
- Aug 2004
- 345
oil sensor?
i have an autometer electrical oil guage, and im confused as to where the sensor/sending unit mounts. any help. thanks
09-22-2004 #2I was just working on this - mounted mine behind the distributor right next to where the trans mounts up (big block, not sure if small block is different).
09-22-2004 #3
- Aug 2004
- 345
is there a port there? i'll have to look in the morning.
09-22-2004 #4
- Aug 2004
- Maine
- 594
I put mine (small block) on the port by the distributer. I had a little trouble clearing the intake and distributor though (that sender is kinda big) and I had to use a little brass extension fitting to get it positioned right. Works great though.
John
09-22-2004 #5update - I may use the port low on the driver's side of the block in the front. Depends on which one fits better - I'll probably have to drop the engine back in the car with the headers so I can check the clearance.
