      Jul 2018
      Single leaf car/Multi leaf housing
      I'm in a jam and might be having to move very soon. I have a 12 bolt that came out of a multi leaf car and I want to put it in my single leaf car to avoid having to pack/haul etc.. So, as you know, the depth of the spring perchs are about 1.5"-2" different (eyeballed, I have not measured yet) TURNS OUT, ACTUALLY ONLY 1" DIFFERENCE
      Is there a "block" / "Spacer" that would suffice to do what I want until I get settled in to the new place?
      68 Camaro
      Dec 2010
      Fredericksburg, VA.
      I don't know of anyone who sells such a block but with a little careful measuring I see no reason why you could not make a block.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Jul 2018
      A 1" block did the trick. Worked perfect and is doing great on the road. I used 1/2" grade 8 bolts with lock nuts. The spring had a locator pin on the bottom so everything is pin located down to the lower bracket
      Resized_20190826_190110 by F G, on Flickr
      Resized_20190826_190124 by F G, on Flickr
      Resized_20190826_190154 by F G, on Flickr
      Dec 2010
      Fredericksburg, VA.
      That's what I'm talking about. Nice work!
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
