      Jun 2010
      Deployed
      C6 Hub / ARP studs
      Is there a direct replacement ARP 1/2” wheel stud for C6 hubs? Meaning you don’t have to oversized the hub’s holes etc.
      1970 Camaro/DSE build
      Of all the things I found wanting on my C6, the wheel studs weren't one of them. And the factory holes are .509, so 1/2" screw in studs will probably work fine if accurately machined, especially if you are using hub-centered wheels.
      Are you looking to match the fronts, or just want longer studs? If you are looking for longer 12mm studs, Moroso and ARP make them.
      ​John Parsons
      May 2013
      Colton Ca.
      ARP part number 100-7730 should work ? Is there a differences in the knurl diameter in c5 vs c6 ? The ones I posted are a short version and show they're for "convertible" but again I don't the difference in hub. They look like a direct replacement. I'll probably try these for my 70 camaro build with c5 hub.
      I used the arp 1/2- 20 x 3" long on my 68 camaro with speedtech extreme subframe and just drilled them out with a 39/64 drill bit for .625 knurl here at my home with no fancy tools and they pressed in perfectly fine.
      Ahmad B.
      TuoCo, CA
      I've heard these are good for C5 but not C6
      https://www.summitracing.com/parts/arp-100-7731
      Steve
      Check it Out Here
      May 2013
      Colton Ca.
      Quote Originally Posted by eville View Post
      I thought I remembered seeing those! ARP came out with those after I did mine. At the time there was no solution. you can buy the ones posted above and cut them if needed.
      Ahmad B.
