Results 1 to 10 of 10
Thread: Alignment specs
07-28-2019 #1
Alignment specs
Doing my own alignment and I have been running - 3/4deg camber but the inside is beginning to wear out. So I thought I would dial it back to 1/4. Just not quite sure whether to set the camber first and then check caster or the other way round. Been awhile since I did it last time. M thinking camber first and then move to the caster. If I do camber first and I have enough caster after I just leave it be but if I need to add more caster then I need to go back and revisit the camber setting. Sound reasonable?
Ok, finished up with the camber. Got it down to -1/4degree. Caster to 3.5. Didn't set the toe. Ran out of time. Toe should be just slightly out(1/4") front of tire to back, right?
