    Results 1 to 9 of 9
      Jan 2010
      Louisville, KY
      Smooting 1st gen firewall
      Hey guys and gals,
      I'm putting in an aftermarket A/C system and welding/smoothing the firewall where the old heater core was. I was thinking about also smoothing the firewall/cowl seam too. My question is - can I just remove the seam sealer, fully weld the seam and then use metal filler to fill the seam. Maybe a little reinforced filler on top of that. I know lots of others have replaced the whole firewall, but I don't wanna do that major surgery. Any thoughts are greatly appreciated.
      David
      Apr 2004
      OKC, OK
      The upper and lower cowls are not the same height. the are 3 layers of metal at the seam. No way to get it flat without replacing the whole face unless you use an entire bucket of mud.
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Aug 2015
      charlotte
      This is what I went with
      http://ambitionroad.com/products.html
      I know you didn't want to get this deep into it but this wall saves a lot of time.
      Has anybody tried this replacement panel?
      http://dynacorndepot.com/firewall-19...a-camaro-69-69
      Mountain Springs, Texas
      Quote Originally Posted by Dave95Z28 View Post
      I saw it on a build thread somewhere. It looked good. Based on a JCG design.
      Edit: Here it is. https://lateral-g.net/forums/showthr...rewall&page=12
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jan 2010
      Louisville, KY
      Thanks guys, I don't wanns do the whole firewall so I think I'll just strip the seam sealer and clean it up some. I'm fine with the seam, but if I could smooth it with a little effort I would. Thanks for the info!
      David
      Aug 2015
      NJ
      I would consider smoothing the firewall for multiple reasons:
      1) you are inquiring about it and afraid to commit. It is worth the effort believe me. I get a ton of comments on my firewall. You don't want to look back and wish you did it afterwards.
      2) you will be putting a bit of effort into sealing that seam and will probably never be happy unless you end up using a 1/2 a gallon of filler
      I did mine myself. Made a cardboard template, plasma cut it and welded on. Here is my thread. Look on page 2
      https://r.tapatalk.com/shareLink?url...0&share_type=t
      '68 Chevy Camaro Pro-tour ~ project DMENTD
      '57 Chevy 3100 Pro-tour pickup ~ under construction
      Oct 2011
      I bought this from eBay but haven’t installed yet. They also make a radiator close out panel. I also asked them to dimple die across the top then weld in the hole.
      https://www.ebay.com/itm/67-69-Chevy...YAAOSwBahVLBuU
      Don
      Thanks for the link. I will check it out.
