      So. Cal
      fuel system help...
      I'm wondering if anyone has any recommendations for fuel system setup for a 383(320whp) with a quadrajet. Specifically from the gas tank to the carb.
      I've got a new carb from SMI (which is great)and now know I have too much fuel pressure. This is in a 69 camaro, that I'm trying to prep for light autocrossing and track days.
      I'm wondering if the stock fuel tank, lines, setup are up to the task.
      The mechanical fuel pump I have now is a street holley unit that I have to add a regulator to reduce the fuel pressure. Should I add the regulator or would a stock replacement fuel pump be enough.
      Would it be better to have a tank with baffles(for cornering?) and a electric fuel pump at the tank then regulator to carb?
      any info would be appreciated!!
      thanks,
      chris
      Newbury Park, CA
      For that power output, a Carter street pump with a built-in internal regulator will do nicely. I have the same pump.
      So. Cal
      Carl
      thanks for the info!
      So. Cal
      I was just looking at the Carter street pump and it says it delivers 6psi.
      I think I need less pressure for the quadrajet 4-5psi.
      any thoughts?
      Newbury Park, CA
      That pump is specifically set up to work without the need for an external regulator. 6 psi should be fine. If in doubt talk to SMI.
      Central CA USA
      I like the Carter street pump.
      Higher volume/pressure pumps are hard on the camshaft. I've heard of cams wearing out from stiff fuel pumps.
