      Jul 2018
      Lost Power steering ... WTF???
      This is a brand new unit part of the Concept 1 serpentine system. I took it for a nice 80 mile run on Friday, started the car Saturday morning and no power steering :surprise:.. . Opened the reservoir and it's full but no fluid movement. I figure i'll pull the lines, drain the system, crank the wheel left & right a few times with hoses off to push out more fluid, blow the lines out, refill, and try to bleed... Any thoughts? advice? Anyone know what pump this is? If it's available from Summit or Jegs or??
      20190429_164856 by F G, on Flickr
      Oct 2005
      Long Island NY
      If it’s a Saginaw pump, the valve may be sticking. Remove the pressure line and the flow valve. The spring and piston is behind. Be sure it operates freely in its bore.
      Peter Bergman
      71 Dart GT, Stroker SB, Built For The Turns!
      Jun 2010
      Deployed
      Most of the aftermarket serpentines are using GM type II pumps.
      Quote Originally Posted by GMachineDartGT View Post
      1970 Camaro/DSE build
      Jul 2018
      I guess I should have update this,, sorry guys for not keeping up. I went with all new everything
      All new stuff,
      AGR 12.7:1 box
      PSC pump
      Moroso Remote resevior
      -10 AN return
      Resized_20190714_123032 by F G, on Flickr
      Resized_20190714_170642 by F G, on Flickr
      Resized_20190714_170634 by F G, on Flickr
      Resized_20190714_170625 by F G, on Flickr
      Jonesboro, Arkansas
      is your problem fixed? it looks like your steering box is as close to your headers as mine is. I think that is why my steering starts out working ok, but in just a few miles it starts getting hard to steer at times.
      Carl Wilson
      Jul 2018
      Fixed, feels great, no issues. I will be adding a P/S cooler
