    Results 1 to 11 of 11
    Thread: Hood weights?
      Aug 2014
      Hood weights?
      I purchased an Anvil Auto dry carbon hood for my 71 Chevelle, and it finally showed up to their facility and they are saying it weighs 30 lbs. That is WAY heavier than I was expecting. They advertise 14.5 lbs, which I figured was BS, but 30 lbs would be more what a carbon/fiberglass hood weighs. I'm trying to figure if this is a manufacturing error or not.
      Can some please share what the weight's of your hoods are. Steel, fiberglass, carbon fiber, carbon/fiberglass. Need info ASAP.
      Thanks.
      May 2013
      Colton Ca.
      I'll try and weight my carbon/ fiberglass hood this weekend for you. I have a full carbon trunk I can weight just because to compare.
      Ahmad B.
      Aug 2014
      Quote Originally Posted by Build-It-Break-It View Post
      That'd be awesome. What kind of car?
      My, what I believe is full carbon trunk weighs about 14-15 lbs. A bit heavier than I expected too.
      May 2013
      Colton Ca.
      It's for a 68 camaro and isn't Apple's to Apple's but should be close by a couple of pounds of each other.
      Ahmad B.
      May 2013
      Colton Ca.
      My Anvil carbon/ fiberglass hood weights 30lbs with spring and hinges. My Anvil full carbon trunk is 9.5lbs. I weighed them both using my mobile freon scale.
      Ahmad B.
      Aug 2014
      30 lbs with hinges... I suspect that puts the hood alone around 24 lbs.
      Thanks!
      May 2013
      Colton Ca.
      If I get time today I'll remove the hinges to get an exact weight.
      Ahmad B.
      May 2010
      kitchener,Ontario,Canada
      Is the hood full carbon ... ? Each hood listed on their site has the weights listed . Or is the 30 lb weight including the box they ship in . I can say with my hood it shipped in a big heavy box with foam wood bubble wrap etc . If I can find someone with a fish scale I could possibly take mine out of storage and weigh it . Mine is full carbon
      Ryan Austin
      On Instagram ryanaustinss70
      Aug 2014
      Anvil's website has weights that are a bunch of BS. Not because they are false advertising, but because they didn't know. Apparently I am the first to order a full carbon 70-72 Hood from them.
      In any case, the weights are hood or trunk only, not including the boxes, brackets, or hardware.
      May 2010
      Absolutely horse**** ...my first hood was order and arrived while I was off work due to shoulder recon ... second hood arrived ... and I wasnt the first by any means.
      - - - Updated - - -
      Where are you located?
      Ryan Austin
      Huntington Beach, CA
      Seems you already got your question answered. But to add another data point. I have the carbon fiber / fiberglass hood (top is CF, bottom is fiberglass) for a 68 Camaro and it weighed 24 lbs.
      I've gotten really into weighing all kinds of things on my Camaro. In fact, I weighed every piece of Anvil Auto Carbon Fiber compared to the steel take offs and wrote a blog post on it. My friend has the new heat extractor 100% carbon fiber Camaro hood and it weights 17 lbs.
      Anvil Auto Carbon Fiber Weights
