      May 2019
      70 Chevelle shorter rear shocks
      The stock length shocks let the springs pop out of the perch when lifting the car by the fame. Looking for shorter extended length shocks. The ones in there now are 20.5" need some about 2" shorter.
      I've got 3" drop springs now.
      Oct 2011
      Philipsburg, Pa
      Give us a call and we can spec some shorter Vikings.
      Keep in mind we have to put the most emphasis on achieving the proper shock ride height (i.e. where the shock sits when the car is ready to drive, full of fuel, driver in car). When you call, have that number available. Center of upper t-bar to center of bottom bolt hole.
      814-343-6315
      Technical Support
      UMI Performance, Inc.
      [email protected]
      814.343.6315
      Join us on Facebook!
      Aug 2005
      Bellevue, NE
      Another option might be some sort of limiting strap or cable.
      DaveZ
      Updated CP Camaro
      No such thing as too much power or too much traction
      May 2019
      Quote Originally Posted by UMI Tech View Post
      814-343-6315
      Sounds good, I'll take some measurements this weekend and give you a call next week.
      Feb 2007
      Tinley Park, IL
      I had the same problem and got a set of shorter Fox shocks from ridetech.
      Nick ~
      1969 Cutlass
