    Results 1 to 1 of 1
      Feb 2013
      Humboldt County
      1966 Chevelle LS3/TR6060
      430hp LS3
      Tr6060 6 speed/ LS7 clutch
      Made 403WHP 398WTQ
      Moser Fab9 rear end, 40 spline axles with wavetrack Posi and new 3:23 gears
      New-Hooker Blackheart mid length headers
      New-Hooker Blackhear 3” mandrel exhaust
      New-Griffin radiator
      New- Might mouse Motorsports Catch can.
      New-accel spark plug wires and Iridium plugs
      New-AAW classic update kit installed
      New-Dakot digital gauges with OBD11 adapter
      New-Vaporworks controller upgraded with E85 sensor and the ability to control Dual dewitts pumps for future HP upgrades
      New-ricks restomod tank with Ls9 pump
      New-PTFE fuel line
      New-brake lines
      New-Ididit column
      New-12:7to 1 steering box
      New-Speedtech front suspension
      New-ATS spindles
      New ATS bumpsteer kit with PRO FORGERS inner tie rods and center link
      New-C5 brakes from Kore3
      New-wilwood 4 piston rear brakes
      New-EBC yellow pads for manual master
      New-15/16 Manual wilwood master cylinder
      New-wilwood proportioning valve
      New-GT pro touring steering wheel
      New-UMI rear upper control arms with rotor joint
      New-UMI rear springs
      New-UMI rear frame bracing.
      Varishock double adjustable shocks
      Hotchkis rear lower control arms
      New- optima redtop
      New- 18’ Ridler wheels
      New-Nitto NTO5 front and rear
      Dash is freshly powder coated
      Grill, headlight buckets and everything up front powder coated.
      The car drives perfect and is all sorted out drivetrain wise. Have a new ACC carpet that will need to be installed.... Due to the larger tunnel, the carped will need to be cut down the middle and have a center console installed, or custom carpet kit. The paint is in great driver quality, but it’s no Barrett Jackson show car. A few things I found that I didn’t like was it used to have a cage in it and I wasn’t to please with the patch panels they installed. Besides that, the floors are in great shape! They also cut out the rear braces for the package tray, but we installed a new setup that I believe is stronger than factory. I also have another frame I will include with the sale. I was going to install the speedtech frame kit and swap it this winter.
      Car is located in Gardnerville NV, close to Reno.
      Asking 38k OBO.
      707-362-6556.
      https://reno.craigslist.org/cto/d/ga...888155380.html
