      1st Gen Camaro - BRP Rear Shock Inboard Relocation Kit
      BRP Rear Shock Mount kit for 1st Gen Camaro - 220 shipped.
      http://www.brphotrods.com/mm5/mercha...gory_Code=CNV1
      This kit allows the use of Left - Right LS1 rear brakes. It also has the provisions for the e-brake.
      Note: The lower shock bolts are not included. I ended up using them on my rear end install. These are stock Camaro lower multi leaf spring bolts.
      Part # 106-5000-00
      Basically installs between the frame rails and lets you put the shocks inboard giving you caliper clearance. I bought it and never installed it.
      Bump
      Still Available.
      Jul 2015
      Newcastle Oklahoma
      I would do $150 shipped to me if you can.
      Quote Originally Posted by Camarowarrior71 View Post
      Thanks for the offer and bump. Not looking to sell it that low.
      Jul 2015
      Newcastle Oklahoma
      Ok, the offer stands if you change your mind. Thanks.
      El Paso, Texas
      Sold!!! Thanks Jorge.
