      May 2009
      Bellcrank for pushrod suspension or shocks, off the shelf?
      I'm just wondering if anyone sells an off the shelf bell crank, or if I have to make one? My rear shocks are binding as the suspension is quite low and the shocks are on quite a steep angle
      Try this:
      Mike Maier inc.
      May 2009
      Try this:
      Mike Maier inc.
      Definitely an amazing all out suspension set up.
      I am just looking for a bell crank only though.
      Quote Originally Posted by Ripped View Post
      Call and see if they will sell you whatever parts you need.
      Oct 2014
      DFW, Texas
      Bellcrank nearly defines the motion ratio of the setup by itself. An "off-the-shelf" unit might not work for your intended natural frequency or packaging. You may end up with too much shock travel per inch of body movement, or the opposite and you nearly can't tune it when running a proper spring rate for the corner's weight.
      Out of all the parts necessary to run a push or pullrod, the bellcrank is something you want to match your setup, which is likely why you aren't finding something like this "off-the-shelf". They aren't complicated to make out of welded plasma cut plate and a machined bearing race.
      I'm certainly not a suspension guru, but I have designed a pull-rod suspension for an FSAE car from scratch.
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
