      FL and Calif.
      Speed sensor question T-56
      Guys,
      I have have viper case t-56 for LSx and I am getting bit frustrated here.
      Do I have place for electrical senser at the top of the lower mechanical gear output?
      At least the electrical sender dont fit in the lower hole and I have electrical speedo meter.
      Or do I need to bay mechanical sender and adapt it to electrical🤯
      Jonesboro, Arkansas
      My T-56 was out of a '99 Trans Am, and it had a place for the sensor in it.
      Carl Wilson
      May 2010
      kitchener,Ontario,Canada
      Ask dodge dealer ...??
      Ryan Austin
      On Instagram ryanaustinss70
      Sep 2008
      Jacksonville, Florida
      The Viper has the speed sensor in the hole that you have the cover on, above the open hole in pic. I haven't seen a Viper tail with the lower hole you have uncovered, so not sure you have the reluctor behind the cover to trigger the speed sensor. Pull it off and see. The T56 speed sensor P/N for the Viper tail shaft is 4848214. When they changed the Viper to the TR6060, the speed sensor in the trans was eliminated.
      Craig Scholl
      CJD Automotive, LLC
      904-400-1802
      www.cjdautomotive.com
      "I own a Mopar, I already know it won't be in stock, won't ship tomorrow, and won't fit without modification."
