    Results 1 to 19 of 19
      Jun 2010
      Deployed
      Miller Built Floater Kit?
      Anyone use one of these 100% bolt on kits? Looks like an awesome kit and easy to install. Looking for feedback, thanks
      Told Bret’s 48 hour Camaro has one.
      1970 Camaro/DSE build
      Apr 2012
      Woodstock, IL
      Sold a few, dealer for him. Haven’t installed one personally but customers had good reviews.
      SchwartzPerformance
      Beach Park IL
      I haven't done a bolt on as I prefer to weld on because I can. I have two in service, I couldn't tell you the miles we have put on them put I can tell you we have been through 8 sets of tires between the two.
      Mechanically they are perfect. We are not easy on them. The only issue I have had is the center cap in the hub leaked, put it back in with RTV and no more problems.
      I don't run the inner seals near the center section, I have before and found they did a better job of keeping fluid in the axle tube than out of it.
      Great product, from a really good guy.
      Donny
      Feb 2007
      I have the bolt on kit on my 72 nova moser 12 bolt. I have about 6-7k miles on it. The only issue I had was a small leak at the axle cap o ring no big deal. I really like the kit.
      Brandon Slater
      1979 Z28
      1972 Nova
      2015 2500 silverado crew cab duramax
      Aug 2010
      Let's say a guy already has a Ford 9" with big ends, Wilwood 4-pistons with Spec 37 rotors and in hat E-brake. Questions: Will the Miller floating system require a new brake set up for the rear end, and will it effect wheel back spacing/fitment?
      Interested.... and I can weld, so how hard is the install to get everything right?
      Joe
      1969 Firebird Project
      1967 Frirebird 400 convertible
      2013 Boss 302
      May 2014
      Stanislaus County Ca.
      Never knew these existed. I need one.
      Pad knock sux!
      Jun 2010
      Deployed
      Quote Originally Posted by ilikeike View Post
      Pad knock sux!
      Kore3 has them too. The problem is the caliper bracket is not designed for the 5.250” Baer Calipers. Told the 48 hour Camaro has custom brackets to make them work.
      I don't see any cons with a bolt on kit. Even with a weld kit you’re still bolting Hubs to the flanges etc.
      Jun 2010
      Deployed
      The kit pushes the wheels out 3/16” on both sides. That’s very minor considering Baers kit is closer to 5/8”. The brakes are a topic of interest, I’m being told the kits fit C5 brakes. Essentially calipers with 128mm bolt spacing. The kit is 100% bolt on....
      Quote Originally Posted by jlwdvm View Post
      Aug 2010
      I have 3/16" to work with since my car is mini tubbed and I an running a 315 tire. I would rather not change out my Wilwood rear calipers. I have also thought about sending my rear back to strange to have it converted to a floater since they area about a 3 hour drive away.
      Joe
      2013 Boss 302
      Jun 2010
      Deployed
      So pretty disappointed...looks like Kore3 was great and contacted Miller about brake brackets. Looks like this kit will only work with C5/C6 brakes. No interest in making brackets to work with Baer calipers. So much for producing products the “customer wants”. It must be me but I dont see too many people running FORD 9” on their corvette or using C5 brakes looking to go floater. Looks like DSE gets the $$ again.
      May 2013
      Colton Ca.
      Are you trying to keep your Baer brakes and still use a millerbuilt floater rear kit? Last time I talked to Millerbuilt he told me he would make his kit work with the 5th gen camaro brembo brakes if I sent in everything to test and paid for the r&d. I ended up contacting Scott at bigbrakeupgrade.com and he made a kit for my speedway engineering floater that would work.
      Ahmad B.
      Jun 2010
      Deployed
      Yea, I already have Baer SS4 for a Ford 9”. The Miller kit is for a Ford 9” but I can’t use the Baer Ford brake kit? I don’t understand that.
      Beach Park IL
      DSE said they can accommodate the SS4 caliper?
      Donny
      May 2011
      Chippewa Falls, WI
      what are you looking to gain with this kit? Sealed hubs, knock back issues? I am in the same boat and have done gobs of research, regarding knockback and pros-cons of different setups.
      Justin N.
      1966 Chevelle
      1992 GMC Typhoon
      1989 Jeep Wrangler CJ 6.0 Twin Turbo
      1981 Jeep CJ7
      Jun 2010
      Deployed
      Nothing. I like spending money and modifying the car.
      Quote Originally Posted by Typhoon1015 View Post
      May 2011
      Chippewa Falls, WI
      in that case, currie has a sweet floater 9 inch setup with huge hub bearings on them. Also Strange has a sweet camber adjustable floater 9 inch housing. since you already have a center section, the new housings are about 2k, which is about what you would put into this miller bolt on deal after buying the kit and the axles to go with them.
      Justin N.
      1966 Chevelle
      1992 GMC Typhoon
      1981 Jeep CJ7
      Jun 2010
      Deployed
      ^^ it would need the DSE brackets. The cost of the axle and getting all the brackets installed again would be pricey.
      Jun 2010
      Deployed
      Does anyone have the BAER kit?
      Apr 2012
      Woodstock, IL
      We use the Baer floater on every Baer brake-equipped chassis we sell. It’s really nice.
      -Dale
      SchwartzPerformance
