      Dec 2011
      new york
      power distribution
      I have an ls swapped g body. Being young and inexperienced when I put it together, I just sent several wires (starter, reverse lockout solenoid, gauge panel, etc. directly to the battery for my constant hot circuits. I want to clean up the wiring by the battery and was wondering which method is preferred to do this. Do I use an aux fuse block or a distribution block? I found a distribution block like this https://www.amazon.com/Terminal-Powe.../dp/B00X32PTDA
      El Paso, Texas
      Depends if your circuits are already fused. The local pull-a-part can be your best friend. I use these from the 88-98 GM trucks. $10 and it has multiple pickup points.
      https://www.ebay.com/itm/1988-89-90-...ss!79925!US!-1
      If you are looking for fused blocks then you can usually find some good GM ones in the trucks. I used one from a newer Dodge Dart that was located on the inside dash. If yards are nowhere near you then this is a good option.
      https://www.ebay.com/itm/4-WAY-ATC-A....c100005.m1851
      https://www.ebay.com/itm/12-32V-Auto...83f3ec992d898e
      Here's links to a couple of guys that have used fuse blocks from Crown Victoria's and 4th Gen Camaros.
      https://www.pro-touring.com/threads/...ght=fuse+block
      Hope this helps.
      Alex
      Orange County, CA
      This has power distribution and fuses
      Orange County, CA
      Dec 2011
      new york
      Thank you guys, so should something like the small starter wire be fused? The guy who did my swap harness just has it direct to my battery?
      El Paso, Texas
      Are you talking the main power wire to the starter or the power feed for the car? If it's the main power wire (4ga. or bigger usually) then I would say no. I don't think even the OEM's fuse that wire. If it's the power feed for the entire car then usually a 50a fuse will work. That's what Painless Wiring puts in their kits. I've never done them but extra security never hurts.
      Alex
