      Dec 2011
      new york
      Clutch line size
      Does it matter the size of the clutch line used? Will it effect pedal effort? I kinked my -3 and have a new -4 on my shelf and would rather use that than spend $80 on new -3.
      Jun 2006
      Should make no difference. It is a ratio of piston sizes between the master and the slave cylinder, I see no way running a larger line hurts anything unless you can't get a bend or clearance.
