Results 1 to 12 of 12
Thread: L.E.D. Install questions???
12-10-2005 #1
Putting LED lights in my detroit dash and ran into a headache. Says i am suposed to put 1/8" holes for them but that is just the size of the bulb. how do these things attach to the dash. behind or in front of the dash??? If it is in front, how big do I need to make the holes? if in back, how do I install them to the dash? I am using a covans classic dash wiring kit and there was very litle info provided. Need to trouble shoot this before monday. Thanks for the quick help - Garrett
12-10-2005 #2I could be mistaken but they should just push through from the back. The base of LEDs should have a ring that is a bigger diameter than the body of it, which will keep it from going all the way through. It should fit tight in the hole. Some LEDs come with a plastic retainer that you put in the hole, then push the LED into. Anyone else have input?
12-10-2005 #3
