      Milwaukee, Wi.
      Extreme duty pistons
      What brand of pistons are people using in their forced induction setups? I have talked to JE, Ross, Wiseco, Arias, BME, Mahle, Venolia and Diamond- now I'm even more confused.
      I need something to handle 20psi and 1,000 hp (cent. blower) in my 383.
      Should I just buy an off the shelf piston or get some custom ones? If I do go custom, what are some of the options I would want?
      Any help would be appreciated.
      Steve
      To add to the confusion add CP pistons in there. I belive them to be the best now but fairly new when compareed to JE or Venolia.
      I think Venolia being very exspensive also have added costs. They dont fit their pins. so your shop would have to do that for you. $1200 pistons with added costs doesnt seem like a deal to me.
      http://www.cppistons.com/Catalog.htm
      Nov 2004
      Roanoke, VA
      FWIW/FYI:
      In the syclone/typhoon community we have been using TRWs under high boost (30+psi) conditions for quite a few years in V6s that are making in excess of 700ftlbs. They are a little noisey due to the loose piston to cyl wall clearances they like but once they get some heat in them they quiet down.
      SRPs (J&Es budget line) have held up pretty well up to 30psi of boost so far but they will not tolerate detonation at anything above 15psi or the skirts like to collapse. They basically seem to be fine for high boost as long as you dont get sloppy with your tune and after speaking with J&E via phone they dont recomend running more than 15psi on the SRPs even though we've had good luck so far with double that amount of boost.
      My .000002
      GMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
      #614 11.9 @ 113
      New stuff finished 08/06:
      4L80E trans w/TCI PCM
      Syclone
      Tow rig
      Apr 2003
      Central Valley, CA
      Ceramic/dry moly coated JE pistons in my Procharged 355, 15psi of boost and about 650hp at the rear wheels. I have 18,000 miles on the pistons right now (8,000 miles naturally aspirated, 2000 with the supercharger and a blowthru carb and about 8000 miles on it now with the procharger and EFI.)
      The pistons and rings looked great when I had the engine apart back in Janurary (8000 miles ago) for the EFI swap and to clean up the aftermath of a failed distributor gear. Very happy with them.
      Also, I'm using 9.2:1 "standard duty" JE's; I'm not running the dished thick-domed turbo/blower pistons as they didn't have an off the shelf blower piston that would give me the compression ratio I wanted.
      One thing to keep in mind with your 383 is you'll probably want short rods; long rods in a 383 means the wrist pin is pushed up higher on the piston into the ring lands, which weakens the ring lands and takes some support away from the rings. The shorter rod will result in a bit more sideloading on the bores but it will keep the pin down out of the ring lands which is more critical.
      Any of the manufacturers you mentioned would be acceptable. I'd try to find an off-the-shelf piston that will do what you want rather than go custom.
      Troy
      1969 Chevelle
      Milwaukee, Wi.
      Thanks for the reply Troy. Some guys will tell you that shelf pistons are not the same strength as custom, but why would companies use different forgings.
      I already have 6" rods so I'm kinda stuck with that comp. height.
      Steve
